pickups
pickups
Postby Brian » Thu Dec 15, 2011 8:13 am
I have a tele and want to change the pickups i was thinking of putting a humbucker in the neck to get a more fuller tone any suggestions would be great thanks
Brian
Re: pickups
Postby Pvee » Thu Dec 15, 2011 9:37 am
I have installed all sizes of humbuckers in Tele's neck position.
The last two which I still have is the GFS Mini humbucker.
Some Tele's have the bathtub routing under the pick guard, but most will have to be routed for the humbucker to set down in there.
I have one mounted in a Black Pick guard that I will sell.
Email me if Interested = ptg1@roadrunner.com
Pvee
Re: pickups
Postby rob » Thu Dec 15, 2011 3:13 pm
The Allparts Mini Humbucker seems to work great in the neck position of my tele......
http://www.allparts.com/Mini-Humbucking ... 50-001.htm
Here's a clip of the pickup i did some time ago.....i'm not connected with Allparts in any way although they used the utube clip on their site.
http://www.youtube.com/watch?v=5ODh9_ab8pc
Rob(uk)
rob
Re: pickups
Postby Jim Prater » Fri Dec 16, 2011 8:52 am
Brian,
I have a tele that I put Seymour Duncan stack humbuckers in that sounds great. I can go from a very bright tele sound to a very mellow sound. I used a Tele Little 59 for the neck pickup and a Vintage Stack for the bridge pickup. Except for my 1968 ES-335, this tele is the most versatile guitar that I have.
These pickups look like single coil pickups and fit in the guitar without routing.
Jim Prater
Jim Prater
Re: pickups
Postby smokymtguitar09 » Fri Dec 16, 2011 10:12 am
Hi Brian,
I had a Fender 1952 reissue Hot Rod Deluxe with a mini-HB at the neck position. I eventually sold the guitar, but here is a YouTube demo of the guitar, concentrating on the HB that you might find informative.
Good luck with the project.
http://www.youtube.com/watch?v=AYb7H_65z0Q
Re: pickups
Postby Brian » Sat Dec 17, 2011 5:25 pm
thanks for the info guys I am going to research this a little more and i will post something when i change it
Brian
Re: pickups
Postby Norm » Sat Dec 17, 2011 6:53 pm
This guy built his own using components available online. I forget exactly which company made the guitar parts but he gets a pretty good sound out of it.
Excellent, excellent, player on top of it
http://www.youtube.com/user/chet1952
I reccomend you [u]all[/u] check his site out. He's added some New Stuff. The guy does an excellent note-for-note and you can see it all plainly
Users browsing this forum: No registered users and 23 guests
