6122-1959 Tone Caps
6122-1959 Tone Caps
Postby alexjones » Fri Dec 09, 2011 2:45 am
Hey Everyone,
I just had a thought - I am not sure if it has been talked about on the board before. Has anyone experimented with different types of tone caps for their Gretsch CG or NC? I haven't messed with the harness before, what kind of cap is in there? Is it just a generic or an "audiophile" quality cap. Just thought I would see if anyone has any interesting suggestions.
Re: 6122-1959 Tone Caps
Postby Norm » Fri Dec 09, 2011 12:21 pm
From my archive of Paul's remarks.
"...When Chet and I talked about the old Gretsch guitars he always said he didn't like those switches as they had them but he could never get Gretsch to do them right.
He never cared for the tone switch on Gretsch guitars. He said they made for too much bass. (Gretsch fans call the tone switch the “Mud switch” for the same reason). I changed the capacitors on one of my Gretsch guitars. I was fooling around with that and I've found what I think is the best capacitor to use; a .0022 it rolls off the highs just enough. It's a little trouble to change it out but in case anyone tries it that would be the one. A Mylar cap works best
Paul Yandell_cgp
During the sixties Chet experimented with the switching harness on his '59 and for a while had the selector switch on the cutaway and independent tone switches for each pickup. Later on he had the tone switch taken out altogether. I think this is because a lot of top guitarists prefer the pickups to be unadulterated coming from the guitar and prefer to adjust their tone at the amp level.
I figured that's what Chet had done after looking at the "Best Of Chet Atkins' album cover for months. I actually got my first Gretsch tone setup so the tone switches were independent. It was a chore that took a couple of days to work out but I got it to work.
That guitar got stolen and my next Gretsch guitars I tried taking out the tone switch and putting in an out-of-phase switch in its place. That was interesting but I just didn't use it that much. On my current '61 Gentleman I just disconnected the tone switch altogether because the capacitance seemed so muffling. to me.
Probably one of Jimmie Websters ideas that he talked Ray Butts into designing.
Postby Brian Ingram » Sat Dec 10, 2011 6:58 pm
Up front, I have no specific knowledge of what type of cap is used in any new Gretsch.
Based on my experience having worked at a major guitar manufacturer, I'd bet money the cap itself is nothing special. Most likely, it would be some sort of generic metallized polyester cap, because that would be small and easy to mount on a control or switch.
I can also tell you that monkeying a harness inside of any semi-hollow guitar is a difficult experience. It will be made a LOT easier if you tie a length of fishing line to the shaft of each pot/switch. You then unscrew the nut holding that part on the guitar, and lower the whole thing down into the guitar. The harness needs to be fished out through an f-hole.
Depending on the model and manufacturing technique, the pickups may need to be removed from their mounting rings. It all depends on how the wiring from the pickups is/is not attached to the pot housing, and how much slack is left in the wiring.
Sorry for the tangent. Ultimately, I'm saying that on any production guitar, no one will be spending money on a pricey cap. It would be seen as unnecessary, and eat into the profit margin.
Postby Norm » Sat Dec 10, 2011 8:46 pm
Well, I have no opinion on the cap quality either except to say if I were to pull a harness and replace it I wouldn't mind spending a little money and get quality.
With the Gretsch sealed top guitars you don't have F-holes...you do everything by fishing it out through the pickup holes and, yeah, it's definitely a PIA Project but it is doable. You just need to be patient putting everything back in.
I've rewired two tennies and did my single cut get a couple of times including a total new wiring harness from scratch and all I ever used was scotch tape, strong thread (or a guitar string) a hemostatic clamp and/or narrow needle nose pliers to get everything back where it needed to go.
At the factory they use a threaded "come-along' to draw the switches to the holes. Some of the guys at gretscpages reccomend rubber tubing available at hobby shops that slip over the ends of the switches and pot posts to help feed them back in. I always thought that was a good idea but I never tried it.
Think out what yoiu need doing, take care you put the screws you take out in a safe place and take your time. If you find yourself getting impatient or frustrated, take a break.
Postby LMark » Sun Dec 11, 2011 12:32 am
alexjones wrote: what kind of cap is in there?
Alex, I know that your question goes to "kind." I can't answer that, and would be as curious as you are. I do know, however, that the value is indeed .022, as the schematic reads 223k for the 6122-1959. Back to the "kind" of cap. I bet that it's not Russian Military PIO. Mark
Postby alexjones » Sun Dec 11, 2011 4:05 am
Hey Guys,
Thanks for the responses. I know dealing with the wiring harness on these guitars is a pain - so I am not super excited about changing stuff just for fun. If it was easier to get at - it would be fun to swap some NOS caps and see what happens. Just thought I would ask if anyone has tried anything with an interesting result.
Postby Brian Ingram » Sun Dec 11, 2011 8:50 am
Norm's quote of Paul is where it's at.
You could spend any amount of money to get a particular type/brand of cap. However, the real key is experimenting with the value to find something that's workable without being "mud only" (unless of course, you need a mud option for your music).
Norm wrote:With the Gretsch sealed top guitars you don't have F-holes...you do everything by fishing it out through the pickup holes and, yeah, it's definitely a PIA Project but it is doable.
Doh! I guess it shows that the manufacturer I worked at has a lot of models starting with "ES". And I forgot they also have models where you have to work through the pickup rout.
Postby Pvee » Tue Dec 13, 2011 9:45 pm
After reading this post, it spurred me on to fixing my old 6120 blue gretsch. I owned it for 3-4 years and was never satisfied with the tone control. barely turning the tone control killed the highs and the tone especially noticable on the neck pickup. So tonight I changed the cap to a known .022 ufd and it is a nice improvement.
The one I took out was marked .022 but it was either bad or mis labled. I tested the tone control with both caps before actually soldering in the new one. Glad I finally got around to it. Maybe I will play it more now. It is a very nice guitar
Pvee
Postby Brian Ingram » Wed Dec 14, 2011 1:08 am
Notice though that Norm's quote actually talks about a cap 1/10th smaller, at 0.0022uF. You might also see these as 2200pF.
Postby Mike Nye » Tue Jan 03, 2012 12:49 am
I replaced the MUD SWITCH on my '61 Country Club with a 500K pot, using the same cap . . . WHATTA DIFFERENCE ! ! !
Users browsing this forum: Google [Bot] and 16 guests
