Butchie Bar update
Butchie Bar update
Postby Joeb » Wed Mar 03, 2021 12:26 pm
Stay away. This does not work unless you modify with re drilling out the holes. at least in my case. Joeb
Joeb
Re: Butchie Bar update
Postby nasonm » Sat Mar 13, 2021 11:41 am
If I was gonna get something like that I'd probably get the Vibramate String Spoiler
http://www.vibramate.com/vibramate-string-spoiler.php
nasonm
Postby ralphnjoann » Thu Mar 18, 2021 4:11 pm
I think it was Paul Yandell who came up with the idea of pulling the pins out of the bar, then drilling the hole through to the other side. The strings went through the hole and on to the tuners.
ralphnjoann
Postby Mike Nye » Thu Mar 25, 2021 12:09 am
ralphnjoann wrote:I think it was Paul Yandell who came up with the idea of pulling the pins out of the bar, then drilling the hole through to the other side. The strings went through the hole and on to the tuners.
OR, you can change strings on yer Bigsby the EZ way, and also keep it stock . . .
Just squeeze the brass ball ends outta round with pliers, just enough for them to slightly bind on the pins. That way, they won't keep falling off while re-stringing. Now, you can change one string at a time without pullin' yer hair out!
Then, by the time you're ready to re-string again, the ball end holes have re-rounded just enough to where the strings come off with ease.
Postby ralphnjoann » Sat Mar 27, 2021 12:53 pm
...or you can attach the string to the Bigsby, keep tension on it whilst clamping it to the fretboard with a capo, then attach it to the tuning peg.
ralphnjoann
Postby Mike Nye » Wed Apr 07, 2021 2:06 am
Yes, you can use a capo, but it's much quicker to slightly pinch the brass ball ends with pliers. Even quicker, if you pinch two or three sets of strings at a time . . .
Postby BillB » Wed Apr 07, 2021 9:28 am
I still use the wedge eraser method that Norm (the Norm) suggested back in earlier Chetbord days. I don't take all of the strings off at the same time, but I clean the fretboard and middle part of the guitar as I go. To me, it's a bigger chore to replace strings on my classical, but even that's not a big deal to me. I'm just too lazy to do it as often as I should. :D
Bill Bailey
