hey you band in the box users...a question...
Postby thenorm » Sat Dec 18, 2010 8:54 pm
Is there a setting that will take your chord sequence and increase the speed each time the set played?
Kinda gradually make you play the piece a little faster automatically. Having to stop and nudge the tempo number makes you break concentration
Re: hey you band in the box users...a question...
Postby GaryL » Sun Dec 19, 2010 7:10 am
Hey Norm,
It's easy to do as follows:
1. click on the bar where you want to increase the tempo (could decrease too if you wanted to)
2. edit
3. settings for current bar
4. change the tempo with a new value or by a percent change
5. hit okay
You can do this more than once if you like.
Postby thenorm » Mon Dec 20, 2010 8:59 am
What I was hoping for was something that would automatically increase the tempo at the start of the next cycle.
Be good for learning a lick if it would slowly and steadily increase the tempo, without having to stop and boost it
Ah well...
Postby RandeDager » Mon Dec 20, 2010 9:13 am
Hey Norm,
Unless I'm missing something, I believe that that explanation would solve your problem. If each measure is programmed with a tempo increase then the song will automatically play through all of the measures.
Postby thenorm » Mon Dec 20, 2010 10:08 am
sorry
foggy early morning reading
I'll give it a shot and report back
Postby thenorm » Mon Dec 20, 2010 10:33 am
It works!
Thanks.
Now I get to run myself over like getting hit by a snowball rolling down a mountaing
Postby GaryL » Mon Dec 20, 2010 11:34 am
Norm,
Glad that worked for you.
