Thumbpick strumming
Thumbpick strumming
Postby Chuck » Thu Aug 28, 2014 6:22 pm
Are there any tried and true techniques for strumming with a thumb pick?
Thanks in advance for any suggestions.
Chuck
Re: Thumbpick strumming
Postby Norm » Thu Aug 28, 2014 8:48 pm
There are two or three versions of this song by Tommy. 'Classical Gas' is not a song I particularly like although I do like the version he does in the video I watched
https://www.youtube.com/watch?v=TQJ1k2HMoRU
Being able to use a thumbpick like a flatpicker uses a flat pick is something that should be easy but tends to be difficult for some. I know I never got good at it. Chet, of course, could do it flawlessly too and seasoned players (Bresh comes to mind) can do it so it's not like it is a secret.
Any guitar technique is attainable...
...if you are willing to isolate it, figure out what is required to achieve it and apply the time (and often monotonous) practice until your eye, hand and mind allow it to happen.
It's like when we learned to get something like the "independent thumb" It seemed impossible for months until one day it stars to kick in.
Isolate what you want to do. Do it SLOWLY until it balances and gradually increase your speed. There are no shortcuts.
Having said that, some folks who have the technique down may propose tips...wrist angle, holding the pick, etc. but it still boils down to play it right slowly before you try to play it up to speed.
Postby Drail » Thu Aug 28, 2014 10:51 pm
Chuck, the first line of your post disqualifies me from answering your question, but being the hard head I am, I will attempt to answer anyway.....lol :D
In my limited experience I have found that the shape of the picking point makes a big difference when trying to strum with a thumb pick. I had trouble strumming with some of the thumb picks I have used but I found one that has a more rounded point similar to a flat pick, that makes it a little easier to strum. You may all ready have a thumb pick like that, in which case, I'm out of suggestions. Hope this helps Chuck.
Btw..... I like your picking so keep up the good work!
- the (not) expert -
- Darryl
Drail
Postby Norm » Sat Aug 30, 2014 9:33 pm
Here's an interesting thought.
I stumbled on this on gretschpages where a guy is talking about having problems getting up to speed using a flatpick.
___________
So, off to the general interwebs, where I was trying to find primers on mandolin technique or anything, really. I happened upon a book about right hand picking by a Mark Burgess called Right Hand Picking (duh). Smack dab on page 4, I see my problem. I'm not holding the pick correctly at all. I've held it pinched between my thumb and the pad on my first finger.
NormNote: This is, I think, the way most of us grab the blade of the thumbpick when we try to do the flatpick business.
Burgess' technique is to lay the pick on the side of the index finger between the two joints and clamp the thumb down on the top of the pick to hold it in place.
The fingers stay curled in towards the palm.
____________________
I just now grabbed my guitar and tried this and there IS a difference. You have to re-think things a little. Instead of using your first joint on your finger to hold the blade you use your second joint. There is a definite difference.
I would definitely suggest those who want to double on the pick to try this.
The picking motion is more of a twist of the wrist than a forearm-driven strum.
Postby rickr » Sun Aug 31, 2014 4:08 pm
Chuck. I tried to contact you offline no response.. Rick
rickr
Postby Art Sims » Sun Aug 31, 2014 11:13 pm
Chuck, Experiments have produced a personal conclusion for me that the main reason thumpick strumming is difficult is because of the angle at which the pick strikes the strings. If you watch closely where video clips show close ups of Chet’s right hand you can sometimes see him changing the position of his hand in order to strum with the pick. I think that’s necessary because muffle licks position the point of the pick directly at the strings whereas a good strum needs the underside of the pick to glide over the strings, at least to a degree. With upstrokes the task is greater and where both downstrokes and upstrokes are desired even greater yet. I think some guys are able to do it by relaxing the thumb enough for the joints to actually rotate just a little bit with the pick and/or for the flesh to move just a bit to aid in the angle of the pick being mildly variable. These are among the difficulties that make flatpicks preferable for some fingerstyle players except that the trouble with that is you then have only the pick and two picking fingers instead of three picking fingers, unless you give up the pinky as an anchor and develop it instead as a picking finger. In my opinion, these options are limited solutions but do seem workable for some finger pickers. I think a player just has to try until he or she figures out something workable in their own case.
Art Sims
Art Sims
Postby Chuck » Mon Sep 01, 2014 7:23 am
THANKS everyone.
Chuck
Postby Norm » Mon Sep 01, 2014 12:18 pm
Too many people treat a thumbpick like they need to find one that has a blade that is just right.
Better you should find one that feels good and fits on your thumb and do some shaping on the blade. Chet did. He tended to round the points off the blades.
I've talked about this before but it's worth retelling. Take a flatpick and noodle around comfortably with it.
After a bit, take a look at how much (or how little) of the pick sticks out from the edge of your thumb.
If you think about it, that is all you really need sticking out to make the thumbick work. It is probably less than the untrimmed thumbpick is.
